I have a Kenwood Model 600 with two output transistors gone on the right channel. The two 0.47 Ohm, 5 watt resistors part number MPC71 are both cracked. I have everything else I need to rebuild the power amp for that side and replace the outputs except for these resistors. If anyone can recommend a source or suitable replacement I would appreciate it. I am currently looking at Mouser Part # 588-TWW5JR47E. It is wirewound 0.47 Ohm, 5 watt resistor.
BTW, for those tracking Model 600 serial numbers this one is 350116.
