hello, I have a pair of Qa's,. One of the emits produces no sound and reads nothing. I don't remember if the woofer was partially blown or not. There is a single Qb for sale on cl. My question is .. could I swap out the emits and woofers on those ? thanks -Q
Yes, same woofer and same tweeters. There are 2 versions of those tweeters, with centered and offset mounting holes, check for that. You can fit them anyway doing new screw holes, but they will look different.
Check tab soldering on the non working tweeter. It was reported bad many times. Reflow the solder, just in case.
Yes I will try that first. Just a lil worried about the magnets doing the fly together and break thing as stated on the reflow thread. Thanks a lot for the info elnaldo ! -Q
Good Point! The Qa and Qb have the same cabinet and woofer, you could turn a Qa into a Qb by adding the 4" Phillips mid range. Those mids were used by many manufactuers and are widely available, choose the enclosed back version. You would need to copy the crossover in the Qb but it is very simple. Use film caps on the tweeters for that Infinity sound!
