My secret underground lair is, well, underground. My upstairs antenna is no better than using a coat hanger on the tuner below ground, in fact it's slightly worse. In my case, the reason is simple. I used small diameter lossy coax because it was easier to route. Turns out anything gained by the upstairs antenna is lost in the cable, plus a slight bit more to emphasize what an idiot I am. At some point I need to run some decent cable. For now, I use a wire in the basement.
