I don't understand the cap hook up on my KLH 24 series II speakers. there is a single cap with 2 values on it, 8 uF and 16 uF. Any suggestions what I replace this with?
Two separate caps.
I saw the info about the proper dope for the surrounds. They don't sound too bad now, but I was thinking of doing that to them eventually too. Not that some of the "homebrews" that people have come up with are bad, but I want to use the correct dope, if possible.I've got the 22's. Same dual cap set up. Like you, I had to return to parts express. 22's and 24's are the same speaker from everything I've read. Nice sounding little bookshelf speakers. Good solid bass too. You'll enjoy them after the recap. FYI, Vinatge AR on ebay has the correct compound to put on the cloth surrounds. Bass response will be even better after the surrounds are done.
Slow project, but finally getting there. Replaced the caps in one of the speakers. Noticeable difference in the clarity of the tweeter. Picture shows what went out and what went in.
I found my sketch I made of the crossover when I took it apart. It shows a 3 ohm resistor 7 watts as the original. I put a 10 watt version of a 3 ohm in my replacement, even though it didn't need to be replaced. I confirmed it with a picture that I took of the original.About to recap my KLH 24s (same cap set up as above) and just want to confirm that white rectangular component is a cement resister. If so, 8 ohm, 10%, 2 leads? I've already got the caps.
Thanks very much. By the way, that pic you took of the before and after recap is printed in color and sitting beside me as I type. It is as close to a step by step as anyone could expect and very helpful.
I'm assuming you've already switched to the opposite channel on your amplifier and checked balance etc. Otherwise, frozen voice coil? Does it move when you push on the cone?Well a problem seems to have emerged in one of the KLH-24's. Recently unpacked them from a move (CT to VA), hooked them up and not getting sound from the woofer of one of 'em. Opened it up, all connections were solid and correct. Removed the woofer and measured resistance at 5.35 ohms which isn't perfect but should be within tolerance. Checked out the caps that I replaced and they're measuring in spec. Any and all assistance appreciated.
Edit: tweeter appears to be fine.
Excellent call and I do thank you. Frozen voice coil. No movement whatsoever. I'm assuming the fix is to replace the woofer?I'm assuming you've already switched to the opposite channel on your amplifier and checked balance etc. Otherwise, frozen voice coil? Does it move when you push on the cone?
