Hello, I have a pioneer sx 1050 and i need assistance.
About a month ago, while in aux mode for tv, my wife said the receiver just turned off. I got home and turning the main power switch on and off did nothing, was like it was unplugged.
I started by removing the case. I then installed a new main fuse (same rating). Tried to power up, still nothing. Tapped on and around around the protection board looking for something obviously loose. Suddenly the lights came on real dim and was greeted by a nice cloud of smoke off the surge current board. Then main fuse immediately melted.
I ordered a surge board off ebay, installed. Read up on this forum about possible causes of blown fuses. Saw that Bridge Rectifier could be to blame, I removed old rectifier from power board, it had burnt smell so replaced it with new one. It did however check out fine with my meter. I think it smelled burnt from possibly running hot over time.
Then got to testing and removing outputs. Discovered in right channel one bad npn @ 1.6 ohms and one bad pnp at .4 ohms. Orded new set from Mouser according to suggestions (http://audiokarma.org/forums/showthread.php?t=125460). Ordered mouser 863-mj21193g (npn) and 863-mj21194g (pnp) replacements. Got 4 for each for each channel (all 8) and installed.
Read that you should always dim bulb test, so i made a tester out of some things I had hanging around my work area with a 60 watt bulb.
Fired up and immediately the light came on full brightness (short). Pulled all output connectors off amp board. Fired unit up again and all lights came on. Test light came on bright then dimmed.
I attach the outer connectors (npn) and turn unit back on. Test light came on bright and dimmed. However, when I attach inner connectors (pnp), the protection tripped and light came on full brightness and stay bright. I removed and tried only left pnp, same result. Tried just right pnp, same result, both sides short.
I am hung up at this point. Still unsure why connecting the pnp transistor outputs shorts unit out. I have removed the semi and use my meter to look for a short but cannot find one with semi removed. Even printed out full service manual with 3 right binder and been studying the schematics for the last 2 days. What have I missed?
Thanks I appreciate the help.
