Greetings all! A new project for me. First set of separates. They are a little scruffy but I think they will be a cool first project. First thing was to pop the covers off, blow the dust and stuff out and have a look. A fair amount of rust here and there but not too bad.
Next step, power up on the dim bulb tester. The 17S preamp powers up with nary a glimmer from the dim bulb tester. Power indicator comes on. Nice! The 19 makes the bulb glow pretty bright and no indicator lights come on. So I shut it back off and think about it for a bit. I remember reading that sometimes it takes a bit for the big filter caps to charge so after sniffing around and feeling for any heat and not finding anything I turn it back on again. Soon the bulb begins to dim and the right power indicator comes on. It continues to dim and the left power indicator starts to flicker and then comes on solid. After a while the bulb on the dbt is barely glowing.
I didn't want to try the power meter test on the dim bulb tester so I plugged it into the wall and tried it out. Shockingly all the LEDs worked! I let it warm up for a while and then checked DC offset. Had 25.8mv on the right channel and 23.8mv on the left. After running for a while the right heatsink peaks out at 106f and the left at 89f hmmmm! I wonder if the delay in the left power indicator coming on and the lower temp on the left heatsink is related. Will need to check idling current at some point. More soon.
Cheers..........................Todd
