andx0r
Well-Known Member
The speakers are my Mirage M-5si's, which have a power handling rating of 70-200 watts, sensitivity of 84db, and a 6ohm nominal/4ohm minimum impedance rating.
I mostly played these with a Sony N77ES/E77ESD combo, which obviously had no trouble with them.
Months ago, before I sold it, I had a Kenwood KA-8150. A heavy, 4-ohm stable, dual-power-supply amp rated at 75wpc into 8 ohms. When I hooked these speakers to that, it was utter fail. Even with the knob cranked past 12 o clock, it simply couldn't open the Mirages up. They sounded like they were under a mattress. This was an amp that never failed to perform with any other speakers I used.
I'm trying to sell these speakers and was looking for an amp to demo them for a friend. My only options are both receivers, one a Kenwood KR-1000, which is 4-ohm stable and packs 120wpc or something like that. But, it's huge and weighs a ton and I didn't feel like pulling it out.
So, solely on the virtue of being much lighter, out comes a very modest Onkyo TX-860 that is one of the first peices of audio gear I ever bought. Single large-ish transformer, not especially heavy (25lbs?), 80wpc into 8 ohms, but it's rated to deal with 4 ohm loads. I completely expected it to fail like the Kenny did.
The Oinker has been driving these speakers with real authority for the past 3 hours and isn't even hot. Not bad for a random find from years ago. Sounds good too, a lot like the Onkyo Integra A-8087 I used to have.
So, what exactly am I missing here? Is there some other spec I should be looking at that would explain the difference? I honestly believe that the Kenwood should've been the heavier hitter of the two.
My buddy didn't buy the speakers, btw. His wife shut him down.
