gizzyman47
My PL-600 table started acting up. The arm "raise/lower" function stopped/started/stopped working a couple of weeks ago.
I had just replaced the arm belt last month thinking that was part of the problem. Anyway, those issues are not related I discovered.
So yesterday I decided to open it up again to see if I could fix the issue.:scratch2:
I was sure it was the switch needing some deoxit. To do this is more of a pain than installing the tonearm belt. You have to remove the board to gain access to the switches. There are about 8-10 screws you have to remove to be able to remove the board. Really, not that bad! I was glad that I didn't have to desolder anything though.
Anyway, got it all put back together and It's working fine so far! Hopefully I don't have any more issues with it, I have vinyl to listen to dammit!
