Mark is downright awesome (Heck, this is his list!
) but the 2SA725's are in the Control amp and EQ boards as well. Order what you will need but the 1010 sounds fantastic when playing vinyl and the EQ will benefit with Marks list. Oh, The power supply should be rebuilt. Forgot to mention that.
Pioneer SX-1010:
Muting Assembly (AWM-039-A)
AWM-039-A: C1: .47uF 50v CEA: 667-ECQ-V1H474JL .47uF 50v
AWM-039-A: C2: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
Equalizer Amp Assembly (AWF-013-0)
AWF-013-0: C1: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C2: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C5: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C6: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C9: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C10: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C11: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C12: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C19: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C20: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C21: 220uF 16v CEANL: 647-UKL1C221KPDANA 220uF 16v
Q1: 2SA725: 512-KSA992FBU
Q2: 2SA725: 512-KSA992FBU
Q3: 2SA725: 512-KSA992FBU
Q4: 2SA725: 512-KSA992FBU
Control Amp Assembly (AWG-027-0) (Check C49-52, can be 100uF 16v instead of 47uF 16v like the manual states)
AWG-027-0: C1: .33uF 25v: CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-027-0: C2: .33uF 25v: CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-027-0: C7: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C8: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C13: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C14: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C15: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C16: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C23: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C24: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C25: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C26: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C29: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C30: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C31: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C32: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C39: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C40: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C41: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C42: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C45: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C46: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C47: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C48: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C49: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C50: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C51: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C52: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
Power Amp Assembly (AWH-032-0) (Times two) (Check board number, the D version does not have the 1.5uF cap.)
AWH-032-0: C1: .68uF 25v CSSA: 667-ECQ-V1H684JL .68uF 50v
AWH-032-0: C2: 1.5uF 25v CSSA: 647-UKL1H1R5MDD1TA 1.5uF 50v
AWH-032-0: C4: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWH-032-0: C8: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
Q1: 2SA726: 512-KSA992FBU
Q2: 2SA726: 512-KSA992FBU
Q3: 2SA726: 512-KSA992FBU
Q5: 2SC1451: 512-KSC3503ESTU
Q6: 2SC1451: 512-KSC3503ESTU
Protection Assembly (AWM-062-0)
AWM-062-0: C1: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062-0: C2: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062-0: C3: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C4: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C5: 4.7uF 25v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWM-062-0: C6: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
Q7: 2SC1384: 512-KSC2690AYS
Power Supply Assembly (AWR-054-0)
AWR-054-0: C8: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C9: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C10: 100uF 63v CEA: 647-UPW1J101MPD6 100uF 63v
AWR-054-0: C11: 100uF 63v CEA: 647-UPW1J101MPD6 100uF 63v
AWR-054-0: C12: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWR-054-0: C13: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWR-054-0: C14: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWR-054-0: C18: 1000uF 35v CEA: 647-UPW1H102MHD 1000uF 50v
AWR-054-0: C19: 220uF 16v CEA: 647-UPW1V221MPD6 220uF 35v
AWR-054-0: C20: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
AWR-054-0: C21: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
R11: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
R12: 10 Ohm 1/4 watt: 660-MF1/4DCT52A10R0F 10 Ohm 1/2 watt
R20: 3.3 Ohm 1/4 watt: 660-MF1/2DCT52R3R32F 3.32 Ohm 1/2 watt
R21: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
Q1: 2SD313: 863-MJE15032G
Q2: 2SC869: 512-KSC2383YBU
Q3: 2SC869: 512-KSC2383YBU
Q4: 2SB507: 863-MJE15033G
Q5: 2SA628A: 512-KSA1013YBU
Q6: 2SA628A: 512-KSA1013YBU
Q7: 2SD313: 863-MJE15032G
Q8: 2SC1384: 512-KSC2690AYS
BOM List:
647-UPW1A331MPD | 4
647-UKL1H2R2KDDANA | 6
667-ECQ-V1H474JL | 1
647-UPW1C101MED | 4
647-UKL1H4R7KDDANA | 4
647-UPW1E101MED | 7
667-ECQ-V1H334JL | 2
667-ECQ-V1H224JL2 | 2
647-UPW1V101MPD | 2
647-UPW1V221MPD6 | 1
647-UPW1J101MPD6 | 2
647-UPW2A471MHD | 2
647-UPW1C222MHD | 2
647-UPW1H102MHD | 1
647-UPW1H470MED | 2
647-UPW1V4R7MDD | 5
647-UPW1E100MDD | 6
667-ECQ-V1H684JL | 2
647-UKL1H1R5MDD1TA | 2
647-UKL1E101KPDANA | 4
647-UKL1C471KPD | 2
647-UKL1C221KPDANA | 1
647-UKL1C100MDDANA | 2
512-KSA992FBU | 12
512-KSC3503ESTU | 4
512-KSC2690AYS | 2
512-KSA1013YBU | 2
863-MJE15032G | 2
863-MJE15033G | 1
512-KSC2383YBU | 2
