I've got two SX-3900's.
My favorite one just came back from the Tech and was pronounced in 100% working order BUT, I found something I had never run across before.
I have my SX-3900 set up with an SG-9500 and an SR-303.
As a total unit, they function correctly on the AM Band, the FM Band, Tape Monitor 1, Tape Monitor 2, Phono 1 and Phono 2 with the SG-9500 and the SR-303 ON. If, however, I try to stream computer "on line" music from a site such as MonkeyMedia, through any of the proper settings, both the SG-9500 and the SR-303 seem as though they are turned OFF and will not react to the music on the Aux setting with the Adapter in the ON position.
SO, of course, here is the question: Has anyone else had this experience and if so, is there a solution to this problem?
I hope I have made this clear. If not, please ask questions.
Thank you.
Thank you.
