My SX-737 has clicked off for a while, but it usually just snapped right back on a couple seconds later. Over time it started taking longer and longer, and now, it's pretty much just constantly in protection mode whenever it's on. I was looking around online and came across this thread with similar issues. (http://www.audiokarma.org/forums/showthread.php?t=483797).
Using my multimeter, I tested the pin values MarkTheFixer posted, and almost every one of them was totally off. Using pin 4 as a ground, the rest of the values are as follows while it was in protection mode; Pin1: 5.5v, Pin2: 5.5v, Pin3: 5.2v, Pin9: -40.8v, Pin10: -13.2v, Pin11: 0v, and Pin12: -41v.
Obviously these are severely incorrect, and I know very little about the inside of this stuff. Any thoughts or ideas on what's wrong and what I should do next? I assumed I'd just have to replace some stuff, but looking in the case, I don't see any blown caps or burnt transistors, but it seems like there's more components underneath that I can't see that could possibly be bad.
Any help is appreciated and I can answer any questions or take pictures or do whatever tests people recommend. Thanks in advance.
