likestoparty
Good afternoon, everyone! I am trying very hard to comingle all of the stuff I've read about amplifier circuits and apply it to a diagnosis and repair of a Kenwood KA-87 that sounds nice for 10 minutes and resets into protection. Turn off to cool down for 5 minutes and it will repeat the 10 minute working->heat->shutdown cycle.
I am having difficulty locating a schematic/service manual that could really help me identify two trimmers that may help adjust current or bias to reasonable levels.
This was a wonderfully working amp until two days ago when I took it apart to clean the accumulation of dust and crap off the PCB, De-Oxit the front controls (badly gunked balance slider was the rehab target), and tackle my first attempt at DC bias measurement and adjustment. Welp, of course it didn't go smoothly. I disconnected the AC line, wrapped a small screwdriver with a blue shop towel to clean the crap off the board, and ZAP!! Most of the way through, the screwdriver arc-welded itself to R41 due to some residual charge. It was a spectacular lightshow! You can see the repair I had to make to the resistor above the right-side trimmer, soldering a new lead extension to the end that was welded to my favorite TV repairman screwdriver. The repaired resistor measures the same as its sister next door. Why not just replace the resistor? I have $8.57 in my account until Tuesday, so I'm stuck home reading and teaching myself about stereo repair.
So, in the cleaning, resitor repair, etc., the two trimmers pointed out in the picture are no longer for sure in a calibrated position and I would love to know exactly what it is they trim. As I understand it, if the DC bias at the speaker terminals is off and those trimmers are not related then it will require faulty component removal, checking, and replacement. So, I'm crossing my fingers that they are related. I found a copy of the service manual available for download for $4.99 from an unusual site, but I don't want to spend 58% of my empire's wealth on something that may be a scam. I also believe the only people who should be paid for a service manual is Kenwood, an authorized distributor who will give me a printed copy, or a collector selling me a copy, not some Belarusian online PDF database. I digress.
So, first priority is asking nicely if anyone happens to have a service manual for a KA-87 so I can get to know the circuit sectors better and see what Japan has to say about calibration. Secondly, I would welcome any pro-tips on what my next move is, service, measurement or knowledge-wise. The bands on those damned old blue resistors are nearly indistiguishable to go in and check component values blindly. Would DC measurement at the speaker outs interest you? Is there something else to suspect is causing the thermal anomoly? Thank you so much in advance for any advice and guidance.
Your pal,
Jon Darby
Your pal,
Jon Darby
