I've got a question regarding high speed diodes for power supplies. Should you always stick with the same specs (in this particular case stick with a UF4004 to replace a 1N4004) or is there an advantage to increasing the specs to say a UF540X diode?
Also, what about Schottky diodes? What is the advantage to using them? What would be a suitable Schottky replacement for a 1N4004?
Thanks.
Thanks.
