elektronror
Well-Known Member
The wood is scratched, dinged and discolored. The grill has small cracks in the paint and is also discolored. I think it is time this amplifier got a new look.
First obvious question. What veneer to choose? Unfortunately it is impossible to find something here in Sweden but the prices aren't high on Ebay.
I've got a color in mind but i have yet not found the right size (all to small) but i still got a lot of lists to go through.
The second is how to fix the grill. I need to get the old paint stripped first but how do i do that? Since the cracks are only on the outer edges i would assume sanding it with a fine paper would be a easy way. Any other ideas?
Then there's the question if i should remove the old veneer before i attach the new one. I would say yes but how do i then remove it?
