This is what I have so far
Kenwood KR-5030/5330
Audio (X09-1240-10 B/2) (Power Supply Section)
Cm49,50:10,000uF/50V (ale-pol) 35x80mm 2-pin tab
667-ECE-T1JA183EA (Snap In 18000UF 63V ELECT THA)
Cm52:22u/50V (ale-pol) use 47uF/63-100V
667-EEU-FR1J470 (Aluminum Electrolytic Capacitors - Leaded 63volt 47uF 6.3X11mm LS:2.5mm Bulk Strait)
667-EEU-FR1J470B
Cm53:100u/50V (ale-pol) use 220-470uF/63-100V
667-EEU-FR1J221L (Aluminum Electrolytic Capacitors - Leaded 63volt 220uF 10X25mm LS:5mm Bulk Strait)
667-EEU-FR1J221LB
Cm55:220uF/16V (ale-pol) use 220-470uF/25V
667-EEU-FR1E331 (Aluminum Electrolytic Capacitors - Leaded 25VDC 330uF 8x11mm LS3.5mm )
Cm56:100uF/16V (ale-pol) use 470u/25V
667-EEU-FR1E471YB (Aluminum Electrolytic Capacitors - Leaded 25VDC 470uF 8x15mm LS 5.0mm)
Cm57,58:220uF/35V (ale-pol) use 470uF/35V
667-EEU-FR1V471 (Aluminum Electrolytic Capacitors - Leaded 35VDC 470uF 10x16mm LS5mm)
Dm15:M4C-3 (200V/10A bridge? with heatsink)
512-GBPC2506W Bridge Rectifiers 25A Bridge Rectifier 25x25mm
567-624-60AB (21x21x15mm)
Dm17:WO6B
512-1N4004
Dm18:YZ-140 (14V zener glass 500mW)
512-1N5244B
Dm19,20: WZ-240 (24V zener glass,DO-41)
512-1N4749ATR
512-1N5252B Fairchild 24 V, 0.5W Zener
Qm25:2SC789(Toshiba,70V,4A,30W@25Ccase,hfe=40-240@0.5A,Ft=3MHzmin,TO-220AB,BCE)
512-KSD363YTU (BCE)
Audio (X09-1240-10 A/2) (PREDRIVER)
Cm1,2:22uF/25V (tant-pol) I/P coupling
667-ECQ-V1H225JL (Film Capacitors 2.2uF 50V 5%)
Cm3,4:0.22uF/35V (tant-pol)Sub-filter
667-ECQ-V1H224JL (Film Capacitors .22uF 50V 5%)
555-RFS25V220ME3#5
Cm7,8:47uF/16V (ale-np)
647-UES1E470MPM (Aluminum Electrolytic Capacitors - Leaded 25volts 47uF 85c 10x12.5 5LS)
Cm11,12:1UF/50V (ale-pol) (tone)
667-ECQ-V1H105JL (Film Capacitors 1uF 50V 5%)
555-RFS50V010ME3#5
Cm17,18:10UF/25V (ale-pol)
555-RFS35V100ME3#5 (Aluminum Electrolytic Capacitors - Leaded 10uF 35V 20% Audio SILMIC II)
Cm19,20:100uF/10V (ale-pol)
Cm21,22:10uF/25V (ale-pol)
Cm24:330uF/50V (ale-pol,16(D)x35mm) (-47V filter,use 560uF/63V)
667-EEU-FR1J561L
Cm27,28:1uF/50V (ale-pol)
667-EEU-FC1H1R0
555-RFS50V010ME3#5
Cm33:47UF/10V (ale-np)
Cm34:100uF/25V
667-EEU-FC1J101
Q1,3:2SC2261(O)(y) (Sanken,80W,TO-3)
Q2,3:2SA981(O)(Y) (Sanken,80W,TO-3)
TO-3 micas (Need a total of 4): 534-4636, 534-4667, 534-4636
Dm1,2,5,6,9,10:1S2076,1S1555 (100mA,35V,DO-35)
512-1N4148TA
Dm3,4:STV-4HG
Dm8,16,17:WO6B (DO-41,Glass)
512-1N4004
Dm11:1S2076A (35V,150mA,250mW,trr=8ns,C=3pF,DO-35)
512-1N4148TA
Qm1~4:2SA750(1)(E) (TO-92,ecb)
512-KSA992FTA (Vce=120V,Ic=50mA,Pd=500mW,Ft=100M,hfe=300-600,TO-92,ecb)
2SA1083,2SA1034(D)(E)
Qm5~8:2SC1775A(E)(F) (Vce=120V,Ic=50mA,Pd=300mW,Ft=120M,hfe=400-1200,TO-92,ECB)
512-KSC1845FTA (Vce=120V,Ic=50mA,Pd=500mW,hfe=400-1200,Ft=110M,TO-92,ECB)
512-KSC2316YTA (Vce=120V,Ic=800mA,Pd=900mW,hfe=120-240,Ft=120M,TO-92L)
Qm9,10:2SA872A(E)(F) (Vce=120V,Ic=50mA,Pd=300mW,Ft=120M,hfe=400-1200,TO-92,ECB)
512-KSA916YTA (Vce=120,Ic=800mA,Pd=900mW,Ft=120M,hfe=120-240,TO-92L)
Qm11,12:2SD600K(E)(F)/2SC1567A(Q)(R) (TO-126,ECB)
512-KSC2690AYS (NPN,Ic=1.2A,Vce=160V,Pd=1.5W,Ft=155M,hfe=160-320,TO-126ML,ECB)
863-2SC3902S (NPN,Ic=1.5A,Vce=160V,Pd=1.5W,Ft=120M,hfe=140-280,TO-126ML,ECB)
Qm13,14:2SB631J(e)(F)/2SA794(Q)(R) (TO-126,ECB)
512-KSA1220AYS (PNP,Ic=1.2A,Vce=160V,Pd=1.5W,Ft=155M,hfe=160-320,TO-126ML,ECB)
863-2SA1507S (PNP,Ic=1.5A,Vce=160V,Pd=1.5W,Ft=120M,hfe=140-280,TO-126ML,ECB)
Qm19,20:2SC1890A(E)(F) (Vce=120V,Ic=50mA,Pd=250mW,hfe=400-1200,Ft=200M,TO-92,ECB)
Qm21:2SC945(Q)(R) (Vce=50V,Ic=150mA,Pd=250mW,hfe=400-270,Ft=250M,TO-92,ECB)
512-KSC945CYTA (Vce=50V,Ic=150mA,Pd=250mW,hfe=400-270,Ft=300M,TO-92,ECB)
512-KSD1616AGBU
Qm22,24:2SA733(Q)(R) (Vce=50V,Ic=50mA,Pd=300mW,hfe=250-1200,Ft=180M,TO-92,ECB)
512-KSA733CYTA (Vce=50V,Ic=150mA,Pd=250mW,hfe=120-240,Ft=180M,TO-92,ECB)
Qm23:2SC1735(E) (Vce=100V,Ic=500mA,Pd=800mW,Ft=120M,hfe=150-300,TO-92-L,BCE)
512-KSC2316YTA (Vce=120V,Ic=800mA,Pd=900mW,Ft=120M,hfe=120-240,TO-92L,ECB)
VR1,2:500ohm pot
652-3309P-1-501
Tuner(X05-1480-10 A/4)
Cg22:47u/50V(ale-pol,dc filter)
Cg25:1u/50V(ale-pol,dc filter)
Cg49:220u/16V(ale-pol,dc filter)
Cg85,86:3.3uF/10V(tant-pol,sig coupling for phono i/p)
Cg87,88:47uF/50V(ale-pol,sig coupling,sig coupling for phono feedback)
555-RFS35V470MH3#5 (Aluminum Electrolytic Capacitors - Leaded 47uF 35V 20% Audio SILMIC II)
Cg97,98:4.7uF/50V(ale-pol,sig coupling,sig coupling for phono o/p)
667-ECQ-U2A103ML (Use across the AC switch terminals)
667-ECQ-U3A103MG
