Hi guys/gals. I'm a bit of a noob to the vintage audio repair game, so please bear with me. A few months ago, I bought an old Pioneer SX780 off of Craigslist. It was in great condition and played perfectly for a few months. Then, when I moved the receiver for a work party, it stopped working. The relay click would click about every 5 seconds and a brief flash of sound would occur, with periods of silence in between. I browsed these forums extensively and have made the following changes:
-I blew the dust out of the casing and cleaned solder joints with isopropanol.
-I replaced both STK0050 Darling power packs with new units from Audio Lab of Georgia and replaced the heat sink compound on both sides of the heat sink.
-I cleaned and reapplied heat sink compound to the heat sinks for the three transistors near the power packs. It should be noted that I had a very difficult time removing Q25 from its heat sink and the transistor broke in half in my attempts to remove it. I carefully superglued it back together and reinstalled it.
-I resoldered all joints for those three transistors.
-I constructed a dim bulb tester.
Where I stand now: when I power on the unit with the dim bulb tester, the bulb flashes briefly and becomes dim, indicating that there don't seem to be any shorts. However, the relay does not click at all, the LEDs do not light up, and there is no output through either channel.
At this point I believe the problem is above my paygrade. Any and all help would be much appreciated!
