Yantraimages
Member
I just read through Nicks amazing adventure with a similar problem with his sx850 and I am hoping I do not have to do as much of a rebuild as he did but all the advice and encouragement that he got was excellent. All the back and forth is very informative to me, another SX850 owner with that damn relay problem. I hope I don't have to go through what Nick went through and my voltages are odd in a different way. I am the original owner and I Love this receiver. I am ordering some Walsh Ohm 2s and really want to run them with my sx850 but I have a sometimes intermittent relay problem but right now the relay won't actuate at all. I have downloaded the bad schematic for the 850 and the good maintenance manual for the 750, wish I could find that for the 850. I did have one guy work on this unit and he wrote on the receipt that "intermittent power caused by bad solder connection INSIDE the power transformer- normally this is a fatal problem, got lucky was able to gain access to internal transformer wiring and resolder connection." Well that's cool and I appreciate him describing what he did but it didn't work for very long, and went back to it's old relay behaviors. I put it away for a few years and pulled it out this week turned it on and it worked pretty amazingly well for a week and now it is back to it's old habits. Right now the relay won't click on at all. I did the tests on the ??power supply board that you mentioned and to me the voltages look very different than what Nick was running into. I got
1 0v
2 .805v
3 .805v
4 3.74v
5 3.75v
6 17.98v
7 17.97v
8 12.14v
9 12.13v
10 12.14v
11 8.95v
12 0v woo hoo!
13 13.1v
14 50.0v
15 18.55v
17 44.3v
18 44.4v
To tell you the truth I am not sure if the relay had actuated or not when I took those readings. It worked ok for the last week, it started acting up this morning and as I have opened it up and looked around and not done much to it really, it went from intermittent to won't actuate at all now. I would Love to hear the Walsh Ohm 2s that I have ordered through the sx850 any help or suggestions would be greatly appreciated. I have had this receiver since 1978 and after listening to it again, well last night, I really want to get this problem fixed. Nial in Santa Fe
1 0v
2 .805v
3 .805v
4 3.74v
5 3.75v
6 17.98v
7 17.97v
8 12.14v
9 12.13v
10 12.14v
11 8.95v
12 0v woo hoo!
13 13.1v
14 50.0v
15 18.55v
17 44.3v
18 44.4v
