I swapped 369 already but I'll do TR305 in a bit.
Cool.
Srinath.
What did you replace it with? Was it a 47µf/35vdc? Check your soldering for solder bridges. Double check for correct polarity*!
* positive lead should connect to the collector of TR305
I replaced it with that was in my parts amp. 47mf/6.3v.
I swapped tr305 with one form the parts amp and it didn't change the situation.
I'll check polarity now.
Cool
Srinath.
the 2sa999 - the cross reference says its equivalent to the 2sa992 and an nte290. I have to look @ what i got in the thing, as well as the rest of these transistors the 2sc2320's.
Cool.
Srinath.
