The JBL LSR305's have changed my mind about what constant directivity can do. Even if you have a kicking HiFi now you might want to pick up a pair of the JBL LSR305's as something to try out. For the price and something you can send back to Amazon without issue it's kind of silly not to do it. I've never tested anything so uniformly flat both on and off axis in the treble range, and they have a ton of detail in there with the reflected sound and direct sound both being damn near flat it makes for a new experience. The areas that it's lacking are in euphoric's, and a realistically sized/shaped sound stage, but closer than normal placement to side walls and running with some toe in seems to help with those issues.
