ultralight
Member
Curious. I do not see a price. Do you know what the seller listed the unit at?
Thanks,
UL
Thanks,
UL
I'm going to do an auditon with my 219IA then the preamp into the 219IA then the preamp and power amps combination to see how it all shakes out. .
Don't remember if any one compared side by side extensive....at least not what I read.
Has anyone her had extensive comparison between the 219a and the 518a? One online reviewer implied that both are very similar and that he can live with either equally well. But others have said that 219 is better - but I am wondering by how much (subjectively) and in what way? Yet I read one person who liked the 518 more than the 219.
So it is a challenging jumble to figure out.
Thanks!
UL
RH67,
Thanks for your reply. Tremendous insight. Since both are laid back, it seems that one would want the detail of the 518 as I think of laid back to also impact the amount of detail retrieved.
Again, thanks for the extended reply. Given your time and number of speakers auditioned, your insight is valuable.
THanks!!
UL
It`s tough with the LM equipment, limited input from owners and a handful of reviews at best, thus the reason i have owned three LM`s in just the last year along with three other brands of amps.
This time before buying the 518 i wanted to make sure that i was buying an amp that was going to meet my expectations so i listened to the 219 and the Shindo 845 amps at six times the 518 price and i`m very happy with the 518, listening to music now is an adventure or a musical journey.
The 845 tube i feel is very special in music applications with a properly designed amp, in my 40+ years of being involved in audio i have never heard such excellent bass reproduction from a tube amp, the texture and fine detail produced in the lower region is crazy good.
A good speaker match with the 518 are the GoldenEar speakers, they allow the 518 to deliver everything that it has to offer.
RH67,
THanks!!
UL
Thanks. I run the KEF LS50.
Did try a number of speakers while searching including the Golden Ear seven which at least one dealer preferred over the two. This is subjective of course. But I tried them with solid state and a lower end Prima Luna prologue one.
Anyways, the Seven was very impressive in its holographic quality. But in the end, the LS50 was simply the most natural/accurate in tone. I think that some may call it the microdynamics. My wife and I have no idea what it is called but it was the most natural sounding of all the speakers we tested all the way up to $2500 units.
If there is any problem, it is that the LS50 is a bit more on the analytical side than I like so I need to test different tubes with the 518 beyond the stock ones to get a bit more body/weight. Also like the LM 502 DAC very much. Significantly better than the Oppo 95/105.
UL
If you have the cash and you don't mind the weight - the 219IA. First it's dual mono and the transformers are much beefier - the bass with speakers that have bass will go down lower and handle it better. Dual mono amplifiers have no crosstalk. There is more dynamics both micro and macro I suspect because the 310A and 300B is simply a better combination and the lower noise afforded the dual mono design will paint a clearer backdrop. The 518 and 218 are excellent and for that matter so is the 211 so this is commentary based with my comparisons.
The issue with comparisons is there is no variable that you can totally control here. Different tubes can change the sound in both so while one could say X is warmer than Y that can reverse by changing the tubes to an extent. I am more of a transformer guy than a tube guy. I'd say the transformer is responsible for 90%+ of the sound. And this is generally where LM is doing well against a lot of stuff since they make their own transformers based on WE designs.
The 518 will be MUCH MUCH cheaper to tube roll and of course to buy. Further you get a lot of tube option in the driver stage. But the 300B isn't one of them. And there are those that like the straight 300B amp from LM.
That's the thing - it's not necessarily about price it's more about which tube sound do you like more. And you hope it's not the one that costs a bomb. IMO detail is usually grain. Elements in the treble that stand out are elements not joined together properly in the time domain and they stand out. But never when I listen to any instrument live do I say to myself "wow check out the detail on that cellist performance. Fraction of a second gaps that allow stuff to stick out more - it's kind of why I am not a big fan of KT 88 and KT 120 amplifiers because they sound too much like SS.
I doubt you'll go wrong with either amplifier but on fuller range loudspeakers like my dealers ATC SCM 100 I think you will hear more of why I would take the 219IA over the 218 or 518. On mediumish sized standmounts on down that may not reveal itself as prominently.
I've said this in my review of the Audio Note I-Zero. You could buy a less expensive amplifier and you could add pricey power cords, pricey tubes and it MIGHT get to the point where they sound as good as the I-Zero. But that's not a sure thing and you could also add those improvements to the I Zero. And with the 219IA you could buy 15 different tubes and add power cords to get it up to the 219IA but then you could do the same things to the 219IA which would then pull it up to ever higher levels. In either one you want to dump the stock 12AX7. My dealer recommended Tung Sol Gold pin http://www.thetubestore.com/Tubes/12AX7-ECC83-Tube-Types/Tung-Sol-12AX7-ECC803-S-Gold
Which are not too expensive.
