Looking good! Are the parts in these new kits lazer cut or still die stamped/cut? I remember the old Sterling kits had some of the worst die stamped parts.
I guess they used new dies because the parts were cut out very cleanly and just required a bit of scoring with the Xacto knife to free them from the balsa board.I used a reinforced cut off wheel in my Dremel to cut the slots for the stringers.
OK1I got the sealing iron and applied the Microlite.The covering material went on well and you literally iron the wrinkles out.I even tried patch panels in case the wing gets a hole in it and it worked well.
Yeah!back in 76 I made the Stuka and the ribs were die crushed not cut.I ended up having to repair quite a few of them.Today the diecut and laser cut parts are much better.
