ron-c
Addicted Member
Clear Audio does make a table with similar performance to the MT10 which of course is in the same price range. Turntable design is all about materials used and distributing resonances so the construction of the table does not reinforce specific resonant frequencies. The construction of the MT10 is very good in this respect and much care was taken in materials used and dampening of the same. When you play a record the goal is to pick up the music vibrations from the LP grove not the turntable vibrating.
If any of you have not looked at the Ceramic / magnetic platter bearing used in MT5 and MT10 it is a brilliant design. The chassis and platter have opposing neo magnets that repel each other so the platter floats off of the chassis. This eliminates the platter thrust bearing that is used on all conventional designs. Since the thrust bearing is air no noise can be generated. If you push down on the MT5/10 platter you will see that it feels like it is on a spring which it is, a spring of magnetic levitation.
McIntosh did not make any secret of partnering with Nakamichi on the MCD205 and MCD7008. These were very popular players that are cherished to this day. The Music Bank system works well to meet the needs of many. It was a big step up from plastic solutions used in other five disk players of the era.
Thanks again,
Ron-C
Thanks again,
Ron-C
