fastfiat81
My first post!
I have been reading for the past month on recapping, etc for a CA-1000 amp I picked up. This is an awesome forum! I have replaced all caps, 2sc458s, relay, class A switches in addition to the pots on the main boards. Deoxited all the switches.
Powered it up this morning and let it warm up for 10-15 min before taking measurements. I have the service manual and am following the steps to adjust it.
First off the DC offset from the speaker ports:
Class A R= -28.8mV L= -4.0mV
Class A/B R= -17.7mV L= +9.0mV
Should I ignore the negatives (-) ??
The main amp boards are where I am having trouble (I think). The pot for the main stage difference are responsive. The others not so much. Seems I can turn and turn them with little or no change in the voltage.
Left board per SM:
a. +15.02 V main stage
b. -.004 V mid point
c. -.026 V class b idle
d. -.029 V class a idle
Right board:
a. +15.04 V main stage
b. -.32 V mid point
c. -.033 V class b idle
d. -.028 V class a idle
Suggestions? Thanks!
Left board per SM:
Right board:
b. -.32 V mid point
