anderslober
Yikes...not again!
Searched the forum....couldn't find any good info.
Specs:Type Designator: 2SC1636
Material of transistor: Si
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.3
Maximum collector-base voltage |Ucb|, V: 50
Maximum collector-emitter voltage |Uce|, V: 25
Maximum emitter-base voltage |Ueb|, V: 25
Maximum collector current |Ic max|, A: 0.02
Maksimalna temperatura (Tj), °C: 180
Transition frequency (ft), MHz: 15
Collector capacitance (Cc), pF: 8
Forward current transfer ratio (hFE), min: 500
Noise Figure, dB: -
KSC1845......??
Polarity: NPN
Noise Figure, dB: -
KSC1845......??
