Newbie here. So in my attempt to run a ground wire between by Technics SLBD20 table and my Lafayette receiver, I apparently broke something.
To begin with, I simply had a lot of buzz even when I connected the new wire (bought online here)
And, even with the wire in correct position, I simply had more buzz than desired. So that issue remains. And, I suppose, I could simply connect a different turntable to the receiver and fix THAT issue.
The big issue is this: Somehow in trying to hookup the ground wire I lost all sound from the receiver. There is no static, no sound whatever (regardless of whether I have the radio or turntable selected). The speakers are plugged in correctly. I was not being rough and jostling the receiver in any major way.
Are there fuses in this particular receiver that might need replaced? Any help would be greatly appreciated.
Thanks,
Todd
Thanks,
Todd
