anderslober
Yikes...not again!
I bought this amp for cheap. It was in pretty poor condition. Faceplate was awful...paint spots all over.....and some yellow stuff that can't come off....plenty of gunk inside...2 blown caps......LEFT side tr's blown...both fuses blown.
Anyway.....as it is a decent amp, I decided to see if I could save it. I recapped the unit...big filters too.....changed all main tr's to NOS. Drivers were changed to ksc2690/ksa1220. I cleaned the unit inside. DBT'ed.....bright...dim..relay clicked.....all ok.....normal power...also fine. Connected speakers...good sound both channels.
Dc-offset was measured at the speaker terminals, no input, no vol., AUX...both channels adjusted easily to 0v. The heatsinks did get hot.
Now.......with meters hooked up across the emitter resistors(0.47 ohm)...LEFT channel measured 120mV....RIGHT channel 160mV...I then
adjusted vr5/6 to minimum.....LEFT channel 64mV....RIGHT channel 104mV.
It can't go lower than this...........as the scat' I have is really bad....can a fellow tell me what the bias should be. I am guessing 25-30mV.
The bias driver is a 2sa899(?)......should I change it?
Thanks.
Thanks.
