bhuskins
I have a Model Eleven III that powers on somewhat...
It turns on, but the only reason I can visually/audibly tell is that the tuner meters respond to tuning. The relay does not engage. No lights work either. No sound output, no VU meter response, no output through headphones.
The timer is OK, but I've temporarily bypassed it to completely rule it out.
All 3 fuses check out fine (out of circuit with a MM)...the 2 main fuses by the transformer and the additional fuse on the power supply board for the lights.
Is it possible that every bulb happens to be burned out? Maybe I suppose, but the other issues might relate?
I've started with checking out the power supply board. I took voltage readings before pulling the board:
Pin 1 (-56v/-49v) -54v
Pin 2 (56v/49v) 51.7v
Pin 3 (-63v) -67.5v
Pin 5 (47vac) 50.4vac
Pin 6 (47vac) 50.4vac
Pin 7 (35vac) 38vac
Pin 8 (35vac) 38vac
Pin 10 (22v) 19.9v
Pin 11 (14v) 13.99v
Pin 12 (33v) 33.6v
Pin 16 (-6.7v) 390mV (For Relay Off)
Pin 20 (7.5vac) 8.2vac
My question is what controls the expected -6.7v on pin 16 that reads low?
I've pulled the board to fully recap it and will replace any needed transistors if something is out of whack on the relay control portion.
All diodes tested good on the power supply board and all of the resistors look good as well.
Any common issues on this board?
Pin 3 (-63v) -67.5v
Pin 7 (35vac) 38vac
Pin 8 (35vac) 38vac
Pin 10 (22v) 19.9v
Pin 11 (14v) 13.99v
Pin 12 (33v) 33.6v
