merrylander
AK Member
I was asked about my recommendation of adding extra heatsink to the voltage driver STK chip in these Yamaha receivers. Rather than simply answer a single member I figured it would be better to post pictures and methodology here.
The extra heatsink is Mouser Part # 707-821702B00 and you will need two as well as some heatsink compound.
Now I dislike drilling holes in metal inside an electronic unit, never can be sure to get out all the chips. I use a right angle ratchet Philips screwdriver to take out the two screws holding the original heatsink to the STK chip. Turn thr receiver over and pull the bottom plate. The two tangs that hold the heatsink to the chassis can be squeezed together gently and the heatsink removed. Refer to the three pictures and see how the extra heatsink can be attached to the original by drilling two holes and using small screws and hex nuts, about a 6/32 x 1/2" should do it. Grease the two new heatsinks and refresh the grease under the STK chip. Replace everything, actually it might be better to add the new heatsinks after you replace the original as they would block access to the STK chip screws.
