So here is what I see.
If the protect is on, and no click of the relay, and no sound from speakers or from the pre out's, I would think you have a regulator problem.
The unit has a +30v, a -30V regulator Circuit.
The thing I see in common is that the +30vdc regulator feeds the power amps, it feeds the Tone amps, the Equalizer, and the protect relay and circuit.
If this 30vdc regulator is bad, your display in front will work, not sure if tuner will work, but both power amps wont work, and you will not get any output on the Preamp outs either.
I would check the emitter of TR701 (or check both sides of R707, and R708, for around 30Vdc if you cant get to the emitter of the regulator.) and look for the necessary +30Vdc. While you are at it check the emitter of TR702 for -30Vdc (or both sides of R709). If the +30vdc is missing on TR701, check the collector of the transistor (metal heat sink) for approx +55Vdc. (and -55Vdc on collector of TR702). If you have no voltage on the emitter, and 55Vdc or more on the collector, then the transistor is probably open. But make sure that the solder connections for these regulators are OK, as they run very hot and can create very bad solder connections or even burn open the foil trace. And while looking at the connections on the board, make sure you don't have any cracks on the board, that can show up usually where the board mounts to the chassis, or where something heavy is mounted on the board.
Good luck
