I tried using my Model 600 as a power amp the other day and noticed the volume output was about ½ of the output while running as “Normal”. It was as though the attenuator switch was set at -15. I checked with 3 different sources thru the preamp but all at the same lower volume level.
If any of you have tried this did you find the same issue?
Thanks in advance
Thanks in advance
