avanti1960
Well-Known Member
Just in general, a question for turntable audiophiles- my thoughts are that speed stability is best achieved without a speed monitoring / feedback control device and the use of very large platter pulleys (or the platter itself).
The "high end" turntable designs tend to have the largest diameter driven pulley off of the belt.
Example- the belt wraps around the edge of the platter, a very large diameter when compared to the pulley on the motor.
This would put more available torque and resistance to drag at the platter and record surface and translate into less variations because of changes in drag on the stylus.
It also means that small variations in motor speed are less noticeable at the platter by virtue of the difference in pulley sizes- the pulley multiplier / ratio effect. This means that small variations of the motor speed would be reduced to a fraction of their actual percentage because the size of the motor pulley is so small compared to the platter size.
Example, motor pulley is 1/6th of the diameter of the driven platter, therefore variations in motor speed will be communicated to the platter at 1/6th of their speed difference magnitude.
Contrast that to a smaller driven pulley - example a small sub-platter- where the sub platter pulley could be 2 or 3 times the size of the motor pulley.
The smaller sub-platter pulley would have less available torque against drag, and be much more susceptible to speed variations of the motor pulley- instead of the platter seeing 1/6th the magnitude of the motor deviation, the platter could see as much as 1/2 the magnitude if the sub platter is only 2X the diameter of the motor pulley.
Smaller driven pulley turntables - e.g. Rega with small sub-platters- tend to drive the need for external speed control units.
Speed control units tend to have the "hunt and peck" phenomena, where the constant monitoring and feed back in minute speed changes can show up audibly. I believe I notice this (on some occasions) with my direct drive table.
So does this make sense? Is the most speed stable way to drive a table is to wrap around the large pulley size of the platter edge?
