I have a different solution:
1. Buy 10 or 15 sets of NS-1000 series speakers.
2. Pull the beryllium drivers and mount them in series-parallel as line arrays in custom-cut compressed-wood "wings". Keep them in horizontally-matched pairs, and mount them with the most accurate drivers in the center. (Alternatively, buy 50 or more speaker sets and use only the most closely-matched pairs.)
3. Put the woofers in line arrays like the woofer towers for the old Infinity speakers (Optional: replace them with Watkins woofer towers.)
4. Rebuild a crossover using the finest caps you can afford, measured for <1% tolerance.
5. Put the leftover cabinets into storage, in case you ever want to reverse the process.
Note: Obviously you may not use the same number of drivers for the columns; if you have enough tweeters, you'll have extra mids and woofers left over.
6. Place the resulting speakers in an appropriately fine-tuned listening room.
7. Sit back and enjoy some of the finest sound on the planet.
This is what I plan to do. It will go in the listening room right next to the one with the Heil AMT line-array systems. That will be next to the "Grand" listening room featuring the IRS Vs.
Yep! I'm going to do this. Just as soon as I win the huge Powerball Lottery...
