Here we go again
The 620 made me cocky so I bought a cheap 640 with the same problem
When the power is turned on the lights and tuner come on but the relay does not click and no sound
I was hoping the 620 and 640 would be very similar but from a first look from the top maybe not
One of the screws on the bottom panel is stripped and is taking a while to get out
Once I do I will check for bad solder connections first
Anything else common in the 640 I should be looking for?
