peterfranks
I pulled out of Goodwill today what I believe are fairly scarce, even rare, KLH Model Twenty-Eight Speakers. Officially called "Multidirectional Acoustic Suspension Loudspeaker System". There are only a handful of posts on AK regarding this speaker and no pictures. Searching the web, very little on them - only snippets. So I'm going to attempt to make this the KLH Model Twenty-Eight thread. I will up-load pictures thru every step of the restoration process and of course will welcome any and all input - especially from folks that own these speakers.
So here is the initial first pass on these:
- overall great condition - walnut veneer over particle board. I'm guessing I'll be able to get out 90%+ of the scratches and wear. No missing veneer, no busted up corners or edges.
- All woofers in great condition - all cloth surrounds intact - no tears or rips. Will need re-doping.
- All tweeters appear original - tweeter + woofers on one speaker all work. All tweeters on other speaker are out - likely bad caps or maybe not.
- Cross-overs will get recapped - more pictures and info on that to follow.
- All speaker grills present but they appear to have been recovered with a velour-type covering. I will be looking for replacement material for grills.
- No pedestals - there are mounting holes on the bottom for the pedestals but those were no where to be found at GW. I might go back over the next couple of days and see if they surface.
- They weigh in at 64 lbs each.
