rlisin
Quad 4 life
After finding a matching tuner for my Sony TA-F55 (the one with funky volume control) I thought I was done with buying Sonys for a while. Well, that was until I saw a TA-P7F + ST-P7J set for grabs, and naturally I did grab!
The units arrived 2 days ago and I must say I love the sound. TA-P7F is one of the best shoebox amps I've heard, and it looks classy! The tuner's fine, too. Listening to this set is a real pleasure. I did not expect it to sound better than TA-F55, but it kind of does. It has all the clarity without the occasional harshness of the 55. And better bass.
Anyway, I tried to adjust the amp in accordance with the SM (and it did need adjustments). DC bias was as high as 30 mV in one channel, 3 times more than it should be. I adjusted to 10 mV - more or less, it fluctuates between 9.5 and 10.5, I figured close enough and left it at that. The amp got significantly cooler after the adjustment.
But DC offset was not that easy. I first adjusted on warmed up amp (1 hour or so after turning it on. It wasn't easy, but I finally managed to find trimmer settings where DC offset was within +/-15 mV and that was as good as I could get it. Like bias, the values were fluctuating, changing from -10 mV to +15 mV and then back again. I remember my friend had similar readings when he tried to adjust his TA-F70. I figured, OK, close enough, rechecked 15 minutes later (still the same). But then today I checked again after turning the amp on. The values were dropping from over 100 mV (in both channels). 10 minutes later they were around 60 mV and falling, so I suspect they eventually drop down to acceptable levels, but it takes quite long, definitely longer than 10-20 minutes. So is this a normal behavior for this type of amp? PPS, heat pipe, Hi-fT transistors and all?
Other than this suspicious behavior, I love this amp. Small, pretty, and sounds real good. Very quiet background for a 36 years old amp. Speaker terminals are crap, but that's my only complain.
And here are some pics, because, you know, worthless otherwise
And here's the other pair:
