First remove all leads, check resistance between B+ and ground and B- and ground, and between each other. Should be some resistance, cap charge and discharge, but no dead short. Then check resistance betweeen AC leads from transformer to Ac line input, should be no resistance, then use a dim bulb tester and check ac going to the bridge, if all looks good, then replace the bridge and try to start the receiver with the dim bulb tester. Hope this helps.
