phatterplatter
Hi...
I have one here that is ALL adjusted according to factory spec service manual
yet , when you add in a signal source and increase input to ANY appreciable level , there is DC also increasing on the outputs, following the input level.
Idle spec DC offset is 0.00 +/- 5mv
Adding signal and output has 100mV..then 200mV...then 400mV
Any ideas??
Thanks:thumbsdn:
Obviously , the protect circuit sees it and shuts the outputs "Out"
Any ideas??
Thanks:thumbsdn:
