GoldSounds
So on a whim last weekend I bought a Fisher 400 off of Craigslist. I’d been thinking about getting into tube gear for a while and missed another Fisher 400 a few weeks earlier. I am now able to post in the Fisher forum and the tube audio forum. YAY!
The unit I ended up purchasing worked fine during the demonstration. I think that the tubes are partially original, the 12AX7s are a mixture of “The Fisher by (unreadable)”, RCA, Telefunken and some that the labels have worn off. The 7868s all have the labels worn off as well.
Physical condition is very good. Faceplate is scratch-free, no rust and only minimal oxidation on the chassis. The dials looks very good; the glass is clean and scratch-free and the lights illuminate brightly. There is no wood case with it. I don’t know to what extent this has been restored if it has at all, but I do know that the previous owner listened to it fairly regularly and was selling due to a surplus of equipment.
The issue is when I brought it home was that the left channel is quite weak. I think that it might be (at least partially) a volume control issue. I found that jiggling the volume control caused the left channel to come on briefly. I was listening through headphones at the time so I’m not sure if it does the same thing for the speakers, but I’d assume so. I can’t image why this happened; I didn’t do anything to it! The sound that I get out of the strong channel is undistorted and noise free. I assume that rebuilding the pot as shown in this thread would solve the problem?
Any advice for repair, upgrades, and the like? Those large can caps on the chassis, are there any drop-in replacements for those? I see them replaced a lot. Also, would a full recap using a kit like those purchased on that auction site be a good idea as well?
Also: I’ve heard something about replacing one of the 12AX7s in the tuner section with a 12AU7 or 12AT7 for better selectivity. I swear I read it somewhere here on AK. I have some extra 12AU7/ECC82s and 12AT7/ECC81s lying around somewhere, would this be to my benefit?
Thanks in advance.
Thanks in advance.
