Yamaha M-70 output DC levels
phatterplatter
Hi...
I have one here that is ALL adjusted according to factory spec service manual
yet , when you add in a signal source and increase input to ANY appreciable level , there is DC also increasing on the outputs, following the input level.
Idle spec DC offset is 0.00 +/- 5mv
Adding signal and output has 100mV..then 200mV...then 400mV
Any ideas??
Thanks:thumbsdn:
Obviously , the protect circuit sees it and shuts the outputs "Out"
Hi...
Any ideas??
Thanks:thumbsdn:
Check your rails both regulated and unregulated. If there stable. Then perhaps a transistor has developed excessive leakage.
BTW when you did adjustments steps 1 & 2. Did you use two multimeters ? This it the adjustment for the +/- 70 vdc rails. Ya really need two meters.
Thanks
I'll check the power supplies again
The thing is ...is that BOTH outputs do the same thing.
Must be something in common
I found out that the feed lines from the Volume Controls are also supplying a small amount of DC proportional to volume level.
That aint good....Maybe some caps that arent true anymore
What does the +P & -P voltages look like. C705 and C706 are the main filters for the P regulated P/S.
