Anyone ever use the Nichicon KA? It seems like they are one of the few "audio" branded caps that are rated 2000 Hrs @ 105°C.
I put them in my Onkyo but haven't actually gotten it fixed so can't say if I like them or not.
Slightly higher grade than the general purpose KT 105*. More suited to digital gear IMHO. They are not "MUSE" caps. I would stick to FG or, if you can get them, KZ.
FWIW, unless they are in the signal path, any modern cap you put in is going to outperform the old, dried up caps that are in there now. Blackgates are unobtanium for the most part. FG's are my goto cap for audio path stuff.
Any downside to using the FGs everywhere, other than the large filter caps? or is it just a cost issue?
P.S.
You'll want some very low impedance/ESR caps to replace any tantalums you find in that CR-2020. I believe the phono section is rife with those little bastards.
I would not recommend using audio grade caps in power supply circuits. Use the right caps for the right job. PM/PW for power, KG for filter caps if you can get them in suitable sizes.
Lots of good info here: If you review the data sheets, you can see the progression of grades and quality as well. KZ is the top dog for Nichicon small cap values, and I feel equivalent to the Blackgate of days gone by. FG is the next best option.
http://www.nichicon.co.jp/english/index.html
http://www.nichicon.co.jp/english/products/alm_mini/pict_f.htm
http://www.nichicon.co.jp/english/products/alm_larg/pict_f.htm
If you can't find what you're looking for at Mouser or Digikey, there's always Parts Connexion. http://www.partsconnexion.com/capacitor_ele_nichicon_all.html
