I have a restored 100-T preamp/tuner(caps, orange drops,solens, LCR, bridge rectifier, all power supply caps). everything works and it sounds great, the issue is the balance control. It will come into balance(I use the Sheffield XLO cd for testing), but the control must be turned to the right(Max B) almost to the 3 position. I would like for it to be in balance straight up. I have tried different 12 AX7s in the V-16 output amp position. Any ideas where I should look. Thanks ron
