Re: I sure did miss you guys
Here is a list of all the Mods I have made to my KLF 30s. Take it for what it is. I will update it if I make any changes but at this point I don't think there is another sound I'd like to hear coming from them.
1. Removed feet and stuck flat onto a piece of carpet. I have hardwood floors.
2. Covered Mid range horns with 2 layers of gutter seal. 1/8th inch by 4" got it at Menards.
3. Stuck 1/4' weather seal foam onto the inside woofer spokes.
4. removed port tubes.
5. Removed all foam from inside of the cabinet, cut a piece of (factory) 1" foam to fit in the top and stapled it in. cut one 3" wide strip and put it down the inside of the cabinet on one side only up against the motor board. Put a piece of 1" foam on the bottom of the cabinet from the bottom of the port holes to halfway to the motorboard.
6. Reversed the wires on the Mid horn.
7. Set speakers off the wall 8.5 inches off the wall and turned inwards and placed so that the distance between the horn centers is twice the distance of the horn center to the side wall.
8. At this time I have a piece of 2" foam spanning from above the port holes to the wall behind the speakers. It's ugly but I think it sounds good. yes I know it sounds odd and I agree that it is. But it is what it is.
9. Removed metal jumpers from terminals and replaced with 12 gauge stranded copper.
The only thing not in this list is the rebuilding of the cabs which basically was remove the motorboard and back board and screw a 3/4 x 3/4 oak ring all the way around both openings so I had a decent amount of wood to screw the panels to. Klipsch had glued them in and they were falling out when I bought them.
This was my post over on the Klipsch audio community so it probably sounds like I'm talking to them. :0
What would one of my posts be without a vid to go with it. theres a couple of more vids of them on my youtube page if your really bored.
http://www.youtube.com/watch?v=3K0f1-ljwpA
Oh yeah I got a new projector too. much better color.
