Not really. The pin spacing is different. The pins one the orignal part are 10mm apart, all the replacements suggested are 13mm apart. A bit too far off for a neat fit.That is a standard type of layout for a relay. You can practically just blindly choose whatever 24V relay you can find, and it'll work completely fine. It looks like the legs might be slightly farther apart than usual though, so you might have to extend them / bend them outward a bit, on the new part.
Hi - I'd second the item recommended by "redk9258"
I just replaced a Matsushita JD2a-DC24V - output relay in a Sony TA-F500ES, with the same pin layout (I think) - with an Omron G4W-2212P-US-TV5. Terminal spacing / pattern was identical, just with slightly larger terminal pins, so had to drill the pcb holes out a little. The relay itself was also marginally larger.
So you ended up with the Omron G4W-2212P-US-TV5-HP-DC24, right? I might buy a couple of these for a couple of JVC receivers I have around here. The sound doesn't come on all of the way until you increase the volume a bit then it's fine. It's not a dirty POT because it has an electronic volume control.
I think FootFungus' suggestion would work too. I'd rather buy from Mouser though.
