The 4315 is kind of unique, in a way, as it was a 'special project' that Greg Timbers oversaw in the 70s.
Ad is still up. Showing eleven days so far. Somebody call Bill and help him get these to a good home.
They are long gone.
Someone is too lazy to remove them.
So whatever happened to these 4315's??
I ended up picking them up. Definately keepers I think. They did/do have some minor issues.... one cabinet had water damage one one corner. I flowed some penetrating epoxy in and then glue and pulled it together with a clamp. I went over the cabinets a little with a sander and applied oil and howards. The mids and woofers were refoamed but on the woofers the foam was glued over the cone edge instead of under. Not sure if I can correct that without ruining the cone. seem to sound great anyway though. Also the grills smalled of cat pee and the badges were missing. I sprayed some product on them before bringing them into the house... wife doesn't seem to smell it lol
Wow, thanks for the comparison with correct ones. Your analysis is spot on. Makes me wonder how much these mistakes effect the sound.
I have done a fair amount of re-foam jobs but I have never undone an incorrect one. Its proabably hard to say how to loosen the glue that was used but what do you guys think I should try? Acetone? Alcohol?
Or should I leave well enough alone for now and just enjoy them?
