Yep. The new one's are bipolar film caps. The tantalums are the audio gear equivalents of IED's. So we replace them with Film caps. They go in either way.
every Mouser transistor has a data sheet available for download.... download them and look them up. then install as per the symbol printed on the pc board at that location.
never ever use the original transistor to determine how the replacement will go in.
from an earlier post:
First you need to learn about what the three transistor leads are about, and identifying which is which and where it goes according to the symbol. Then you will see that my parts list include lead arrangements - which assume the transistor lettering (and flat) are facing you and the leads are facing down, then go left to right.
Q13 2sc938 150v 0.05a 0.6w
512-KSC2383YTA to-92L ecb 160v 1a .9w 50mhz 160-320hfe $0.17
The big TO-220's with the metal mounting plate are hard to reverse, but the smaller ones are, but my specified replacements are usually E C B as a rule of thumb BUT we ALWAYS CHECK...
But you really should start here and follow ALL the links...
http://www.audiokarma.org/forums/showthread.php?t=331932&page=5
here's a preview, DO YOU SEE these symbols on the boards you are working on?:
e is always the arrow on one angled line (direction can be out (npn) or in (pnp) towards the base)
b is always the flat line the other two lines come out if at an angle
c is always the angled line without the arrow
letters can be smudged or illegible, while the symbols are hard to mistake and pretty language independent
pioneer doesn't use letters, if there is a symbol. sometimes in a linear hole arrangement, there is only an 'e'.... with no room for a symbol.
now a quick lesson on installing a small transistor in a traditional triangular hole arrangement with a symbol printed in the center of the triangle
1. find the LEFTmost lead on the package and identify it's designation (emitter? base? collector?)
2. look at the symbol on the board, find the corresponding hole
3. insert that lead into that hole
4. find the RIGHTmost lead on the package and identify it's designation (emitter? base? collector?)
5. look at the symbol on the board, find the corresponding hole
6. insert that lead into that hole
7. the center lead will now need to bent forward or back to go into the leftover hole.
DON'T THINK "WHERE IS THE FLAT FACING"
think
"outside leads" and THEIR holes...
this one's ecb....
and two transistor layouts, ebc and ecb with the same triangular target hole arrangement
well, you do need to get the parts, first....
and when ordering the transistors, mouser has links to the transistor's data sheets, DOWNLOAD the data sheets!!! THEY are your BEST guide as to the correct lead connections for THAT particular transistor.
Do you understand the transistor symbol? enough to identify the emitter, base and collector from it? Because most boards (Pioneer) have the symbol printed on it, with holes around it, and it is orientated so there is an emitter hole, a base hole and a collector hole. And obviously, only the transistor's emitter goes into the emitter hole, the base into the base's hole and the collector into the collector's hole. IF you want it to work...
oh, and by the way, the symbol usually DOESN'T have the E, C and B letters ON on it... :stupid:
there are two flavors,
pnp: arrow pointing in, 2sa,2sb, ksa, ksb part number prefixes
npn: arrow pointing out, 2sc,2sd,ksc,ksd part number prefixes
hint: if "rotating" it in your mind is a puzzler, orient it in the hole this way(transistor hole arrangements are usually triangular):
choose the leftmost lead, use the data sheet to identify it... for example it is the emitter
put it in the emitter hole
choose the rightmost lead, use the data sheet to identify it... for example it is the base
find the base hole, rotate the transistor line of leads around the inserted leftmost lead to point at the base hole
put the rightmost (base) lead in the base hole.
the THIRD hole is now either in front of or behind the transistor, in this example the collector is "left over"
bend the center lead forward or back to go into the hole.
easy...
notice that this example had the lead order of emitter, collector, base which is a common lead arrangement
that means that:
looking at the transistor, with the leads pointing DOWN, and the flat part (or lettering in the case of some zetex transistors) FACING YOU
going from left to right has the lead order of emitter, collector, base
Well, I've finally got a free day (today) to finish everything.
Got the bias sitting nice at 20mv and it "seems" to be working well enough.
One thing that is odd is that when I power the receiver down, the right channel has a little static-like noise (low-ish) and seems to last around 20-30 seconds. - Like a slow discharge? - Any ideas?
Without going thru the whole thread again.......did you replace the Main Filter Caps (6800uf/35V) ? Sounds like one of them may be on the way out. It shouldn't take more than a few (3-4) seconds for the sound to bleed off from the caps discharging. With new caps it's almost instantaneous.
647-UVZ1J682MRD 6800uf / 63v Nichicon. It's about 40% of the size of the original. Either use some spacer material between it and the clamp, or gut the original cap and restuff it with these. This is what i used in my 737.
You could, but i get mine from WJOE.com. Less expensive in lots of ten. And shipping is usually less too. http://www.wjoe.com/all_lamps.htm Get the GF670. 8V 250ma. Then replace all of them.
