Dr. Ear
I got my PX-2 today. Again it is in a great shape, just a small 2-3mm mark on the front right corner. It worked as advertised. Anyway, I decided to clean and lubricate the main bearing, check the solder connections and recap the arm control board. I could see that one of the 1000µF caps had been replaced already so I decided to replace them all.
I mounted a Dynavector 20X2 on a Yamamoto HS1A headshell and unfortunately discovered that this combination is too heavy without the accessory weights (whichI do not have). I cannot close the dustcover because it will hit the adjustment knob of the counterweight.
->> Does anybody have an esthetically perfect idea how to make the counterweight heavier?
