Hi folks, needing advice here. I have a pair of Mc-30 amps, they were last checked about 10 years ago ( I had a tech go through them and check them for marginal or faulty parts, and get them sounding sweet). Lately the one amp will make ( on occasion) loud deep rumbling sounds for about 3-5 seconds and then return to normal. This happens usually after the amp has been on for 30 plus minutes, and occurs maybe 1 out of 6 times. The other oddity is that when I turn the amp off it makes a similar sound after I have "thrown the switch" , although it is not nearly as loud. This happens maybe 3 out of 5 times.
Any idea as to what is going on? Possible things to check out? When it does act up I see no redplating or arcing. Thanks, Ed
