Hi all,
Quick question (kind of) about a Fisher x-101b… I’d like to power this unit up with a dim bulb tester that I just built. I’ve found some very helpful links so far that cover the “general” procedure for using a DBT, but I’m still unsure of a couple of things specific to this unit.
So far what I’ve done:
1.) Powered the unit up with NO TUBES using a DBT (40 watt bulb): Bulb glowed dim – ok so far I think.
2.) Powered the unit up with RECTIFIER TUBE ONLY using DBT (60 then 75 watt bulb): again bulb glowed dim each time; and rectifier tube also began to light).
The above tests were done with volume set to minimum, speaker switch set to OFF, bias pot set just a tick forward of full counter clockwise, and ac balance pots set at midpoint.
I’m assuming my next step is to insert ALL tubes and test with a 100 watt bulb…
My confusion is regarding the proper settings and load on the amp when powering up:
1.) Should the speaker switch be set to ON or OFF?
2.) Should I be conducting the DBT with a load on the amp (cheap speakers; non-inductive resistors)?
3.) Where should the volume be set?
4.) Is the position of the bias pot important for this test (e.g. should bias be set full CCW or as close as possible to its proper position?) - FYI it is a cathode biased amp, 44v at pin 5.
5.) Would it make sense to insert the ouput (7591) and small signal (12ax7) tubes in one at a time to better spot a potential short?
I just want to make sure I get this amp up safely before I plug into full ac and start probing for proper dc voltages.
I totally appreciate any input!
Adam
Adam
