little-al
Why? ...why not
I picked up a previously modified Fisher 30-A last year, and meant to use it as a good training piece for my fledgling hobby in vintage electronic repair.
I recapped my Fisher FM-50 tuner along with some other minor repairs such as new X/Y caps, thermistor, power cord and a general restoration. That worked out well and looked great. So I decided to give the 30-A a try. You can certainly see a number of my questions related to the 30-A and FM-50 in the last months.
Well, other than some minor nits such as a cord strain relief, the 30-A is finished.... for now (always the possibility for more tweaking).
I've recapped the entire unit, using one of the new CE (Mallory) can electrolytic caps. The original spec was 40/40/40uF 450/350/350V, and the replacement is 40/40/40uF 525V. I do have an outstanding question in another thread if larger filter capacitors might be better for the amplifier though. We'll see what comes of that question and if larger filter caps might be of benefit, especially with regard to hum.
I've added a CL-140 thermistor for a softer start-up. I used this instead of the popular CL-80/90 unit because it is closer to the rated draw of the amplifier. I suppose this was less necessary in the 30-A since it is tube rectified than the FM-50 which is SS rectified, but what the heck
As recommended here, I also added X/Y rated "death caps" on each main leg and across the legs for filtering.
You may notice that I used carbon-comp resistors again. The originals were actually in good shape and most tested within spec. So again, no need to replace, but this was more of a learning project for me than anything else. I replaced all of the original 1/2W CC resistors with 2W CC resistors, all are now 5% spec and all except two are mil-spec. My limited research suggested that larger wattage CC resistors would likely be more stable and produce less noise than the smaller wattage units given their ability to be less susceptible to heat induced performance changes. There was also some suggestions that the larger diameter 1 and 2W CC resistors performed better generally. I'm of course not sure that it completely true, but thought it would be an entertaining exercise. The real issue, and usually reason, that the smaller 1/2 and 1/4 W resistors are used was due to physical size. As you can see, the 2W resistors were a bit of a challenge to fit due to size.
I replaced the coupling and input capacitors with Angela (Jensen) paper/oil capacitors. The one that is perpendicular to the other two still has a bit too much play/wiggle due to the long leads than I'd like. I don't think there is any real chance of it "settling" and touching anything or vibrating excessively, but I'll likely tie it down a little more securely.
The one electrolytic downstream is now an Elna Silmic II with the same values as spec. The voltage on this part of the circuit is supposed to be about 10V, so I think 25V is good. I was unable to find a 35V or 50V handy, but may replace that later as doubling the spec voltage on this was a recommendation I had received for longevity of the cap.
I left the one disc ceramic capacitor in place, which I think is an RF ground filter (C2) and should be fine. I may replace it later if my hum issues continue, more on that later. The other two capacitors (C4 & C5) are cylindrical ceramic axial units that should also be fine. I've heard they can have special thermal specifications that are hard to replace. But I may still take a look at these three if it seems recommended. I'm trying to understand that part of the circuit, and wonder if that is for NFB?
The other three wirewound resistors were original the typical cement brick type, and they've been replaced with Dale and Ohmit WWs of the same resistance and a little more headroom on wattage in a couple cases.
So in the end, does it still work? Good news is yes, no magic smoke was released :yes:
Following the advice here, I painstakingly removed only portions/sections of the old components at a time, and carefully (3 times) noted the new components and their connections on the schematics and digital photos.
I checked the main DC voltage and per spec it should be:
315V, actual measured 326V
270V, actual measured 302V
385V, actual measured 388V
The only voltage over 10% is the 270V going to the 12AX7.
Any thoughts on if these are OK, or if some adjustment in resistor value is needed?
I suppose this is due to variances in the components and higher line voltages today.
So, now complete does it sound better, I can't really tell! *laugh*
....but it sounds "good"
Again, I didn't really expect some sonic leap, and it was more about the fun of reworking the parts and getting some practice.
Now that all being said, I still have the same light "hum" that it had before the rework. It definitely is noise getting into the input stage, as I can short the input and it is dead quiet. And at least part of the noise is coming from my house/environment because the amplifier is noticeably quieter if plugged into an A/C circuit upstairs than several in the basement.
Again, all that is left in the amplifier that is original are the three ceramic capacitors, transformers, potentiometer(cleaned and quiet) and of course the chassis, sockets, fuse holder, etc.
So if anyone has any thoughts on the source of the hum based on everything above and the photos following, please feel free.
The hum is manageable, but it would be nice to see if I can eliminate it. I have a 7025 tube coming to test as well to see if its spiral filament may help over the 12AX7. And I've tried several different rectifier and 12AX7 tubes with no difference in hum.
With all that being said, it has been a lot of fun to take this apart and reassemble. I think it will be a good starting point for more complex projects and beginning to understand how these circuits work versus simple part-for-part replacement, the latter which is where I mostly am at this point.
Thanks for all the help over the last months. And if anyone has any thoughts on those final three ceramic capacitors (to keep or replace with something else) and the hum issue, please feel free to comment!
Thanks again,
Al
Thanks again,
Al
