little-al
I asked this question as an aside in an older thread and it was briefly addressed, but wanted to better understand the function/impact of changing the capacitance of a capacitor in a given location of my FM-50 tuner.
Some time back I bought a "resto-pak" kit from Fisherdoctor. The kit was fine, but one thing I was curious about was his direction to change two capacitors from their original value of .1uf to 1uf to "improve bass response".
Both of these capacitors are immediately preceding the output of the "amp" and "recorder" outputs, which are identical circuits of each side of the output 12AX7. The only difference is that the "amp" output has a gain pot on the rear of the chassis, and the "recorder" output uses a "recording level" pot/knob on the front of the unit to allow its use as a simple volume control so the FM-50 can be directly connected to an amplifier.
I am using the FM-50 with a 30-A in this configuration with good success.
The two capacitors in question are C33 and C40 in the Fisher FM-50 Service Manual. In the Sam's Photofact the capacitors are C44 and C49. Their original value is .1uf 250V
Fisherdoc's kit replaces both of these with a 1uf capacitor noting in the instructions that: "Increasing the value of C-40 [and C33] as noted will allow the audio output of the tuner to be more efficiently coupled providing true bass response down to the lowest frequencies, even if the unit is used with a solid state preamplifier."
So, with all of that said, I am interested to understand how this change accomplishes this? I am not doubting his specification, but simply want to understand the theory that applies in this example.
I had a Jantzen 1uf capacitor in hand, so went ahead and used that for C33 versus the more generic poly film in the kit.
Thanks,
Al
Thanks,
Al
